srong gas vapors/odors
I've checked fuel system front to back....no leaks anywhere. Had a mechanic check from front to back...and no leaks were found. He said it was in the smog system. This '79 was originally a California car.
Anyone have any suggestions on how to get repair this and get rid of the gas vapors/odors?????????????????
Re: srong gas vapors/odors (Johnny Whitney)
I had a similar problem with my 71 and found that my vapor canister was damaged. I replaced it and solved that issue. I do not know if 79 had a similar set up. .02$
Location: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Re: srong gas vapors/odors (BLT-71)
My wifes car does that to. It smells worse at the can.
I just dont think it's worth replacing it on a 93 Buick Centry.
JW, I don't know if a Kali '79 has the same system as my federal '72 did nor not....but I know my '72 really well,.....IF it is, I can make several suggestions....
GENE
GENE
don't know if this might be your problem,i had a gas leak,fuel running on right side muffler,thought it was a seam in the gas tank ,turned out to be the cork gasket under the filler neck, $2.00 gasket ,little labor =lots of money saved.
Re: srong gas vapors/odors (1971corvette)
