Heat Insulation Blankets
I have a 75 with the L48 engine..all stocl and original. The heat insulation blanket on the underside of the hood needs to be replaced. Other than the originality issue, how important/functional is this insulation blanket, and, what could be the ramifications of NOT replacing it. Thanks in advance!
Location: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Re: Heat Insulation Blankets (captras)
Heat insulation blanket , MMmm. There ok on your bed.
You meen(sp) the insulation(sp)?
Re: Heat Insulation Blankets (wackedvette)
Ok, its the HOOD insulation blanket...part #609-471 in Mid-America Motorworks catalog. If anybody can help without the attitude, I would appreciate it ..... Thanks
I'm not sure mine ever had one. I've had it 32 years and don't remember seeing one on there. My paint doesn't seem the worse for the wear either, although I alway garage it...
Mine has been off now for over 15 years and I've had no problems with paint or fiberglass. I think it was mostly for sound deadening.
Re: Heat Insulation Blankets (vettfixr)
Should have no probs without one...
and I hear that the replacements aren't original specs?...I've heard others grumbling about them...
