Anyone out there with a Nine inch or Dana Rear in a C3?
I'm looking for information from C3 owners who have had Nine inch/Dana 60 or even 12 bolt rears (non-IRS) installed. Who did it, how much did it cost, and finally how is it working out? I live in Charleston, SC and I got a price from a local builder to have a nine inch put in without shortening it for about $6000. Shortened rears, mini tubs, tubs are extra. It looks like a 4-link set up is most appropriate, but I don't know if the rear crossmember has to be replaced or altered. Does anyone out there have any C3 experience in this area? Thanks in advance for any input.
Re: Anyone out there with a Nine inch or Dana Rear in a C3? (surfolly)
I don't have it in yet.. but I'm getting a Ford 9 inch installed.. I was quoted $5k installed (including parts and labor)
[Modified by GrandSportC3, 9:49 PM 5/9/2004]
Re: Anyone out there with a Nine inch or Dana Rear in a C3? (GrandSportC3)
GrandSportC3 I thought you had purchased another race car that had a 9 inch already installed or am I thinking about someone else? :confused:
Sounds great. If you have a minute...what type of set -up are you getting? Are they installing tubs, rear frame assembly, ladder bar or 4-link, altering the frame or rear crossmember ? I would more or less looking to back-half the car, and keep it streetable. Right now I'm an inch away from buying a Pro Street Camaro(w/o engine) to race and abuse, but I just started thinking that I might do something similar to my 'Vette (not the abuse though). Besides, my wife is really growling at me about getting another project. I really appreciate any information.
Re: Anyone out there with a Nine inch or Dana Rear in a C3? (CrossedFlags77)
Grandsport3, Thanks for the info and good luck! Keep us posted on how the project goes.
Here you go. http://www.http://temp.corvetteforum.net/c3/hotrod12 I did all the work,but have previous experience.
[Modified by big632, 2:19 AM 5/10/2004]
[Modified by big632, 2:20 AM 5/10/2004]
[Modified by big632, 2:22 AM 5/10/2004]
Re: Anyone out there with a Nine inch or Dana Rear in a C3? (Corey_68)
Oliver, I take it you're installing a cage as well?
I don't expect the car to be finished before fall..
BIG632, awesome 'Vette! Mine would be a few notches down in intensity, but I love yours. It looks like you may have put in a tube chassis or something similar. My stepfather built his '82 Corvette drag car with a tube chassis, but for a back-half type application he isn't sure what folks are doing for pro-street type 'Vettes. We looked at a Super Stock C3 when we were at Rockingham Dragway a couple of weekends ago, and it had a modified non-IRS rear that still utilized the rear spring - kind of a hybrid. That set-up didn't help me much for the nine inch application I was looking for. I guess the main thing I'm wondering is if the rear crossmember can be used for the 4-link without cutting it out and replacing it for a back-half project? Thanks very much for the responses.
No .You have to cut it right where the control arms fit in. put in a new back clip with frame rails and suspension locations.Mine is a back half with full cage. Basically you jig weld a clip with frame rails at the width you want.Then you square it in your cut out factory frame.When you square it you measure diagonally to each front spindle,and set it in. You do not use the body,which could be way off. You also have to have the car level at the time you remove your factory frame so you can set your ride height at that time too.Email me if you need more info.
Re: Anyone out there with a Nine inch or Dana Rear in a C3? (big632)
big632, thanks for the information. We have two reputable shops here in town that build hot rods and race cars, even Pro-Modifieds, yet neither has done a back-half street Corvette. I'm driving my mom's '80 (mine has the engine/trans out) to one shop this week for them to look under it so they can give me an estimate. If I go through with this, I may take you up on e-mailing you with more questions. Thank you again for your help.
[QUOTE]Here you go. http://www.http://temp.corvetteforum.net/c3/hotrod12
This Vette makes me :smiliedrool:
Re: Anyone out there with a Nine inch or Dana Rear in a C3? (8T1-7T9 BIONIC VETTE)
This Vette makes me :smiliedrool: :withstupid:
