WTF the tapping goes away after the engine warms up
Omega Aficianado
Iwas tryoing to localise the tapping in the engine I posted about, and it's gone after a couple minutes.. It's got me wanting to drive the car and live with it but I fear screwing the engine up
Re: WTF the tapping goes away after the engine warms up (Markm10431)
:iagree: When your car warms up the oil pressure goes up and helps free the lifter... real easy fix if you take your intake manifold off... that and your valve covers and rocker arms/ push rods.
Re: WTF the tapping goes away after the engine warms up (JMNBRZ)
If you let that go for too long, will there be too much damage? I think thats happening in my DD.
If one of your lifters is slightly out of adjustment, it could be loose when cold untill it expands with the heat. I would check adjustment. If you have a high mileage car, normal wear in the lifter and the push rod can cause a "loose" condition. Dirty gummed up lifters will make noise also. Eather way, it's time to pull the valve covers and have a look.
I have a noise like that. I let Lars listen to it when he visited our town. He simply said not to worry about it. So I don't...
The vacuum operated heat riser actuator-if you have one- has been known to make these strange sounds until it fully opens around 120 degree water temp. Try pulling its vacuum hose to test this theory. (don't forget to plug the hose!) Good luck.
Omega Aficianado
Re: WTF the tapping goes away after the engine warms up (page62)
Re: WTF the tapping goes away after the engine warms up (Marv)
I agree with Mary...It's most likely the vacuum canister for the heat riser. Mine was tapping like that too. I thought I had major engine problems. It was just a loose vaccum hose to the cannister. A $.02 tie wrap fixed it.
Sounds like a lifter is out of adjustment. Just adjust the valves per the service manuals (3/4-1 turn past zero lash) typical Chevy set-up.If any of them won't adjust then you have a bad lifter. Most likely it is just an adjustment. Most of these engine have press in stud that like to work there way out over the years. It may only be a few thousandths but it is enough to make the lifters out of adjustment.
