How do you remove this??
Can anyone tell me how to remove the bezel circled in the pic, mine is looked a bit rusty and I want to remove the metal frame only so that I can powdercoat it black again. :confused:
[Modified by Pauld, 7:10 PM 5/9/2004]
Re: How do you remove this?? (corvgreg)
There should be speednuts on the backside of the body panel.
I had a quick look earlier because I was going out, but it looked at first glance like some plastic studs, what do actually mean by speednuts, do they just undo with a regular spanner? I hope that when I actually look harder it will become clear. :cheers:
Re: How do you remove this?? (Pauld)
Re: How do you remove this?? (80TPIVette)
Thanks guys, found the speed nuts and now have them removed, feel a bit silly now I see how easy it was!! :crazy: Thanks again :cheers:
:jester :jester :jester
