Can this be done? (I don't think so)? MSD Ignition
I've got what I think is a bad 6AL box, I've got 6AL, MSD Distributor, MSD Blaster 2, MSD 8.5mm wires.
I'm not getting any voltage on the + side of the coil (made some other posts about this), but is there a way to bypass the Ign box without replacing the distributor?
David
David
Re: Can this be done? (theandies)
And also you can't check a msd setup with a volt meter at the coil. A digital meter will show nothing. An analog will show 0 at startup and around 4 volts while running, when you actually have around 400 volts at the coil that cycles many times per second.(thats right, be careful) To get a true reading you would need some electronic testing equipment that go beyond a volt ohm meter.
