Oil filter adapter ....
Is there supposed to be a gasket, or an O ring between the oil filter adapter and the block in a stock motor?
1975 L-48
Thanks in advance to any one who knows ....
1975 L-48
Re: Oil filter adapter .... (75Rag)
If I remember correctly when I installed mine it was a 2 bolt which used a gasket btn the adapter plate and the block, the connector doesn't need one as the gasket is built into the filter.
Re: Oil filter adapter .... (Green76)
Green76 is right, no gasket is required, we made one and put it in place as when I took it all apart I wasn't convinced that a small leak was originating in that area - sealed it up good.
