Power Window problem in my 78
I had my windows rolled down today and when I tried to get them back up they do nothing. Do you think it is a fuse to the PW and where do I find the fuse for this if it is this?
Re: Power Window problem in my 78 (78vettman)
fuses are under the dash on the drivers side.
check there.
cant be sure they are there on a 78 but i think so
[Modified by stingraymaniac, 10:43 PM 5/8/2004]
check there.
you might have a loose connection in your switch also. Try pushing slightly around the perimeter of the switch while toggling it. It happens to mine once in a while.
