Hooker Sidepipes: Do yours make a mess?
Mine condense and shoot black condensate everywhere and drip puddles of black water on the floor.
The mixture is about right on the car, maybe a little on the rich side.
Does anyone else have this problem? How do you deal with it?
Re: Hooker Sidepipes: Do yours make a mess? (Steve Straus)
The only time mine ever does that is if I have it running in the garage for a while. Like when I'm adjusting the idle mixture/speed or timing. It would have to sit there idling and doing a bit of revving up for at least 20 minutes or so though. Even then the 'puddles' are very small (1 inch accross).
All the Best! :steering:
Re: Hooker Sidepipes: Do yours make a mess? (SharkPilot)
Steve. I just started mine after it's winter nap, and no black soot but I have condensation. 2 inch puddles. No big thing..........."Sounds great", but I'm partial....... :yesnod: :yesnod: :yesnod: :yesnod:
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Only on warm up :leaving:
I had a set of hookers on my vette years ago with the glasspack insert mufflers. Within a few years both sides of my pipes rusted through where the mufflers sat. I'm a firm believer that the glasspacks trapped and retained the condensation causing this especially when driven on short trips.
Re: Hooker Sidepipes: Do yours make a mess? (Older Than Dirt)
:iagree: same thing happened to me. would rather have the drip then have the pipes rust out. It used to get pretty expensive to replace every year. robert
I can't remember the post, (been a while and probably a senior moment), but there was a setup to push fresh air through the AIR injectors to keep this guy's stock exhaust from rusting out on a '68. Should be simple to duplicate. My sidepipes (not Hookers but similar) have 'packs in them and steam when I fire up and run in winter, but that's it.
Hans
Hans
