Anybody port and polish their own heads?
Cruise-In IV Veteran
Cruise-In V Veteran
I am thinking about porting and polishing my el cheapo pro action torker heads.
Can it be done with a dremel tool or do you really need that air powered grinder?
Any thoughts on the subject?
Re: Anybody port and polish their own heads? (Guru_4_hire)
I did a new set of WP S/R Torquers. I used a die grinder and the kit that summit sells. Takes some time and you have to be careful not to grind into a water jacket and wreck the heads but it's some thing you can do.
Gary
Gary
I used a Sears electric grinder with a teardrop shaped carbide bit. Finished up with sandpaper rolls from Eastwood. It's time consuming but fun.
Cruise-In V Veteran
Re: Anybody port and polish their own heads? (flynhi)
So it is possible.
Is there a book with pictures and stuff on the subject?
I coulda sworn I saw a link here a few minutes ago...I liked it and copied it, some good info and pictures. Here it is:
http://www.corvettefaq.com/c3/Standa...ng%20Guide.htm
-Roy
-Roy
Re: Anybody port and polish their own heads? (Grinchia)
yeah, i just posted that in a thread...great walkthrough...encourages me to port my heads myself :yesnod:
Re: Anybody port and polish their own heads? (71vetteLT-1)
Just becareful and not to get close to the valve seat. If you do, you'll be off to the machine shop, just a heads up. :D
I did my roommates with an air grinder and finished up w/ sandpaper bit at the local hardware store.
:cheers:
:cheers:
