A/C belt guide
A/C belt guide
The tin thing bolted to the upper control arm shaft that keeps the A/C belt off the control arm area ... know what I'm talking about? How far should it be from the belt?
Either I've got something set up incorrectly, or the belt isn't the right length on the compressor, because that belt is hitting the guide with the a/c on. The belt is tight ... but the belt flex allows it to rub pretty well and I've bent the guide as far down as it will go.
What gives? :bb
What gives? :bb
Re: A/C belt guide (SanDiegoPaul)
You obviously have a later shark, with the R4 compressor, similar to my old friend's '78, and if you ever find out how to cure that problem...lemme know...alls I can assume is there is something about aftermarket belts, and them being metric these daze, that alows that to happen.....dunno what else to think....
I beleive the taper of the V notch in the older American cars, vs the taper in the V on new belts, is differant, and so typically the belts after a bit of wear have a concave backside, like from riding on too narrow a V groove for the belt....and in our old sharks, that's an issue with the R4 compressor because it's not a regular in it's firing as say an older A6 or newer Sanden/San-something.....
GENE
GENE
Re: A/C belt guide (mrvette)
Thanks MrVette but it is a '76 Vette. The compressor is the long, 110 pound A-6 unit. Single, 1/2" Vbelt drives it.
:flag
:flag
Its should be about 1/2 to 3/8 inch from the belt just enough to keep it off of the dust cover and control arm. Does yours have a part number on it or do you have a picture available, i would like to see if its the same as others ive seen, I have a 75 and would like to buy one of those belt guides, any body got one for cheap they are not using ,
Re: A/C belt guide (vette75406)
Paul my 77 did that all the time. I had it bent down as well. All I can say is one your belt is not the right length just changin the angle at which the belt aligns along that tab, 2 maybe your brackets are not all 1976 era stuff and again that changes the angle of the belt.
Re: A/C belt guide (Cali,68,L-79)
Thanks David that does make sense. BTW wife and I saw you in Fletcher hills the other day but the lights didn't allow us to get close enough together to talk ... we were driving the MonteCarlo
:cheers:
:cheers:
No P/N is visible ... and when I tried to shoot pix of it last night they were too blurry. I was gonna post them with the original post. I'll try again and let ya know what happens. :crazy: :rolleyes:
