Anyone have a set of Lars recurve weights they're not using?
Since Lars isn't building the recurve kits anymore, I'm trying to put one together myself. I have most of the parts, but I need the weights that came in the Lars kit. If anyone bought one of Lars' kits but didn't need the weights, would you let me know?
Thanks in advance!
Scott
Thanks in advance!
Scott
Re: Anyone have a set of Lars recurve weights they're not using? (Shrike)
Thanks in advance!
Scott
Thanks in advance!
Scott
Since Lars isn't building the recurve kits anymore, SNIP
Are you sure ?
Damn.
Re: Anyone have a set of Lars recurve weights they're not using? (NHvette)
WHAT !?!? Dam Dam Dam ... Damn. !!!!
Are you sure ?
Damn.
Are you sure ?
Damn.
I could be wrong, but I thought the point kits didn't come with a weight set,only the HEI kit did?
Gary
Gary
I got my kit from Mr.Gasket; it came with weights. I was not able to achieve 36* with even the lightest spring and the Mr.Gasket weights. The Mr.Gasket weights are a little bit heavier than the stock ones and the profile is a little bit different i.e. give more advance, than stock.
Good luck
Good luck
Re: Anyone have a set of Lars recurve weights they're not using? (70vert)
Mine is using HEI, so I'd like to get the weights is anyone has 'em. And yes, he is not making the kits anymore, but just do a search for "recurve" and he has posted a list of the various components. Or you can email Lars, I'm sure he would send you a list.
Good luck
Good luck
