Power steering cylinder removal advice
Re: Power steering cylinder removal advice (mvftw)
tried that and it will not move. i hate to use heat under there. am considering dropping the whole system so i can get to it better(even though it is on a lift)and use a press to see if i can get it out. :banghead:
Re: Power steering cylinder removal advice (wcsinx)
will do.got a 4# sledge and along with a 6-pack of adult beverages,will give it another try tonite.
Re: Power steering cylinder removal advice (COMMANDER370)
Get yourself a puller, either a "small pitman arm" or "tie rod end" puller. You will (a) avoid destroying anything, (b) get the cylinder free and (c) have a tools that you will use again on the front end. :cheers:
i had to use a two jaw puller and some heat to push the damn thing out. it was a bit scary because i had to wind the jack screw up several turns past tight. it came flying apart after i wacked the puller with hammer. :smash: :smash: :smash:
Re: Power steering cylinder removal advice (Turbo-Jet)
Take that pickle fork and throw it as far as you can from the garage. :yesnod: Get an air chisel and put it on the casting where the stud goes through, not the cylinder, the rod casting and give it a little shot. That cylinder will fall right out of there without damaging the ball joint. Pickle forks don't work very well anyway, plus they are guaranteed to ruin the ball joint.
-Justin
-Justin
I tried everything too - no go.
I ended up cutting right through it with a hacksaw, and then punching out the stud once the relay arm was off. :eek:
Need a new cylinder anyway. :rolleyes:
