tempature sending unit location
Re: tempature sending unit location (i885744)
......from the wire bundle going to the alternater....there should be a single green wire going to the temp sender. It originally had heat insulation around it.
Re: tempature sending unit location (goinbroke)
Correct answer.... Just beware that replacements (even GM) are not calibrated correctly and the gauge may read hotter than the engine really is.
Re: tempature sending unit location (bluevetteman)
