C3 Vette Body Repair/ Prep for paint
I own a '71 C3 vette that was a basket case when I bought it. I have slowly been restoring and am now up to body work and prepping for paint. Anyone have any direction as to whether or not it is a good idea to take the body down to the glass in preparation for paint? Also, I have been using Dynatron Dynaglass to do body repairs. Has anyone had bad results with using the Dynaglass? anyone with comments/suggestions? :chevy
Re: C3 Vette Body Repair/ Prep for paint (Bnine)
Here's a good starting point by Lars from the corvettefaq site, there are others on painting there so check it out.
http://www.corvettefaq.com/c3/PaintTechPaper.doc
:seeya
:seeya
Re: C3 Vette Body Repair/ Prep for paint (72GACRZR)
Yes I would strip it down to bare glass. Why put expensive paint on top of an old unstable surface? As far as Dynaglass, I would not use it to repair cracks. I would only use resin and mat. Good Luck on your job. Craig :cheers:
definitely strip it down to the glass...if you want your body to looks smooth, do body work on the seams...this totally helps a killer paint job stand out.
