Hydrobooster help needed on adapters/fittings
I finally gathered up almost all the stuff for my hydrobooster setup, and I got it all installed. The only thing that I'm missing are the adapters that fit into the booster (with the O-rings) so I can connect to the braided power steerings lines. I checked with my local speed shop's Earls line of fittings, and found nothing that would work. I hear that Russel has them, but I have no local dealer, and I dont know the part numbers. Anyone had this problem?
Here is what they look like:
Re: Hydrobooster help needed on adapters/fittings (corvettecris)
Not sure if this is any help to you but I just looked at mine and both of the adapters you are talking about have a 90 degree bend in them and after they come out of the housing they point to the front of the car, then the braided hoses attach to the ends. Mine look nothing like the picture you have above.
Re: Hydrobooster help needed on adapters/fittings (Pete76Shark)
the 90 degree adapters connects to these. These adapt from the o ring to the flare.
[Modified by corvettecris, 1:12 PM 5/3/2004]
yep, i see it now. Only one of my 90 degree fittings has the adapter above. The other one looks like it screws straight into the housing. Sorry I can't be of much help here. Call'em up they might send you another one.
