I found my original order copy this weekend
Location: Part breakage is just weakness leaving my Stingray
While changing tach and speedo cables I found a sheet of paper between the gauges.
it reads
ident # 268260 / date received 70/01/26 / exp date of prod 00/00/00
order # ETT373 / zone 2 / dealer 003 / COPO/F&SO (blank)
Model 19467 corvette convert / paint 03976AA 26 Mulsanne Blue
03GV4AB Rear axel 336 ratio
03M20AB 4-speed transmission
03PT7AA F70x15 white stripe tires
03C05AC convertible top/black
03U69AC AM/FM pushbutton radio
03G81AF positraction axle
03F62HS front springs
03G32EA rear springs
03N40AE power steering
03ZK8AB tire pressure sticker
03ZQ3AA standard engine
03400AB black vinyl interior
it reads
'73and'75 (08-11-2020)
Re: I found my original order copy this weekend (Doug70vert)
:cool: Sounds a lot like mine, except mine has the auxiliary hard top. :) I was able to rescue the tank sticker.
Make sure that you register all that info. over at the '70 Registry.
Hi Doug
I see, we have proably the same options on our Stingray‘s. I‘m curious about the „F62HS“ Front Springs and the „G32EA“ Rear Spring.
My rear Spring have 7 Leafs. For this, and the Reason of the 15/16“ Front Rear Bar and the 3/4“ Rear Bar it seem‘s our Car‘s are Equiped with the
„F41“ Handling Option. NCRS don‘t have Record‘s of 70 Corvettes delivered like this... What‘s about your Rear Spring? Standard 9 Leaf‘s or
HD with only 7 Leaf‘s?? Tell me please about. Thanks & Best regards, Markus
