Setting lash with new lifters different than with old?
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Hey all,
I'm in the midst of a cam (hydraulic) swap. I soaked the lifters in oil then installed them. When setting lash, does the method differ with new lifters than with lifters that have already been somewhat "pumped up" with use?
Thanks in advance...
disclaimer I posted a similar question in C4 Tech...No answer yet.
:cheers:
:cheers:
Re: Setting lash with new lifters different than with old? (joeveto)
When you get to 0 lash and you give it the 1/2 of 3/4 extra turn I think you are only pre-loading a spring insde the lifter so it has nothing to do with the oil, so the same proceedure is used :D
[Modified by MotorHead, 8:31 PM 5/2/2004]
