Problems with Steeroids install...
Ok, I'm installing my Steeroids kit, and now I'm at the point where I need to mate the intermediate shaft between the U-Joints. Does anybody else have a problem with the shaft fitting inside the U-Joints? I have one side in, but now it's stuck... Any help is appreciated...
Re: Problems with Steeroids install... (Jasonty)
Here's what i did after fighting with trying to assemble like you are trying to do, i just couldn't get enough play with using major force:
1. I bolted both ujoints to the connecting rod.
2. I then bolted this entire assembly to the rack. I also found out that i had to use the shorter set screws on the ujoint at the rack as these were rubbing against the frame.
3. Bolted the rack in place with the assembled ujoints
4. Bolted up the tie rod sleeves and tie rods.
5. I then unbolted the driver side of the rack by removing u-clamp bolts
6. This allowed the rack to drop far enough so that i could then slide the ujoint on the steering column, this was real easy to do from under the car. It helps if you have cleaned the grooves on the steering column. Make sure that your steering wheeel is centered before sliding on, assuming that you already centered the rack.
7. Bolt rack back in place
8. I then drilled a hole about 1/4" deep into the steering column shaft (this was done with the ujoint on, i used a drill bit that was slightly smaller than the set screw hole so that the set screw could bite in, just like speed direct did on the ujoint shaft. Be careful not to damage threads. I did this because after first test drive i noticed that the ujoint had slid up the steering shaft and it was causing slight binding.
Re: Problems with Steeroids install... (Vette-4-Life)
Hmm, sounds like a plan... So let me ask you another question... Did you have any problems with the passenger side rack & pinion mount? Mine seems like it's too small to fit over the rack and pinion rubber mount...
Re: Problems with Steeroids install... (Indy Year 25)
:iagree: Yup. Only had 2 minor problems. Did a little filing on the shaft to make it fit, and I had to ream out the return power steering hose with a drill.
Re: Problems with Steeroids install... (page62)
dont get me wrong...i LOVE my Steeriods...
BUT...
that return hose is the WORST!
1st of all, it takes three men and a boy to slide that super heavy hose onto the fitting...it has no flex...it is as hard as steel!
so...like you, i resorted to drilling it out...
then...no matter what i did i coundnt get it to stop leaking...
it is WAY to rigid...a clamp does almost nothing...
what i ended up doing was removing it and stripping the rubber completly off of the fitting...
then i flaired the end and put the fitting back on the pump...
then i connected the two fittings with 3/8 auto transmission hose...
works great and NO leaks...
Steeriods is awesome but i have no idea why they use this stupid hose from Hell...
BUT...
I had the same problem with the low side line not sliding over the pump fitting. I used a hair drier for about 5 minutes and lithium grease. It still took some effort to slide on but it is on at least an 1", won't come off unless it's cut. I used a small heater hose type clamp and so far no leak, fingers are crossed.
