rear end part needed
I need to replace the crush sleeve in the rear end,who knows where to buy the spacer that is set up with a tube & shims ,I saw it somewhere but can't remember where.Cost was about 34.00 - 39.00 dollars.thanks in advance
will keep bumping to top till i find
[Modified by 1971corvette, 4:04 PM 5/2/2004]
Re: rear end part needed (1971corvette)
That's a solid pinion sleeve. Ratech sells them http://www.ratechmfg.com you can probably get it from Jegs or Summit too.
Gary
Gary
THANK YOU gtr1999 that is what i needed,if you are ever in the area stop on byso i can buy u a refreshment :seeya
[Modified by 1971corvette, 4:48 PM 5/2/2004]
