ignition coil bracket
Hello corvette friends I would like to no what is the correct ignition coil bracket for a factory 1971 B/B eng. is it a slant unit or a straight up unit ? Also I have a steel vacuum pipe that is connected to the vacuum fitting at the inlet manifold that crosses over the coil bracket location is this correct ? thanks. :seeya
Re: ignition coil bracket (Rob vette)
My 73' BB has an angled one . I would guess a 71' would be the same. If you aren't running the distributor shield I think a straight one would be ok.
Re: ignition coil bracket (Brent Brooking)
PR #: 1847K GM #: 1968423
Ignition coil bracket, all exc. 3x2, includes pinch screw.
For Years:1965 to 1974
Condition: New
Type: Stock
Packaging: Each
http://www.corvette-paragon.com/cata...6-FF4DD0CFD4B1
Homepage http://www.corvette-paragon.com/
:thumbs:
