hood losing it's curve??
I'm not sure how to explain this... My hood looks like it's slightly flatter than it should be. As in, at the front of the hood, the seam between the hood and body match up. At the front wheel hump area the hood is slightly lower than the body. At the back of the hood, it is above the body. It's like it doesn't have quite enough curve. :confused: Anyone else have this problem? Any easy fix?
Re: hood losing it's curve?? (skeptic)
I had the same problem!!. first make sure the front or your hood is level with the nose or surround by shiming under the hinges as needed and make sure your header bar did not separate from under the nose or surround, mine did!! so the hood looked lower because the fiberglass had lifted from the bar. then there are rubber spacer blocks in the drip channel around the hood that give you that flush level look, I think one is placed under the fender curve of the hood. Yours is missing or compressed., As for spacing , whatever works for yor hood!! corvette central or ecklers has shims and spacer blocks :thumbs:
Re: hood losing it's curve?? (LENNIE)
The car was re-painted at some point before I got it, and I'm guessing they took out the blocks to paint, and never replaced them. Thanks for the reply, I may never have figured out I was missing something. :bb
Canadian Events Coordinator
Re: hood losing it's curve?? (BKbroiler)
SPACER BLOCKS!!!
One of mine fell off and I noticed the difference right away....where's that glue? :leaving:
