What fuse?
What fuse?
My wiring diagram shows a fuse of some type in line to the blower relay on the orange wire between where it changes from red to orange, mine has been cut out and spliced together, I would like to replace it .I have a 75 model with a/c, Thanks for the help.
Re: What fuse? (vette75406)
My 74 has a 30 amp inline fuse several inches from the junction block. The wire then runs to the AC relay. You should be able to buy a fuse holder from an auto parts store and wire it in.
Hope this helps
Hope this helps
Re: What fuse? (goinbroke)
does this apear to be a stock setup on your car , i saw a inline fuse holder on a 74 firebird in a junkyard but it looked non stock but also very old like it may have been stock im not sure if it was , if yours is all stock then i may grab that one , im in the process of repairing all the old patches to my original harness and want it to look as much like original as possible, the one on the fb had ridges all around one end and used a glass AGC type fuse , does that sound like yours ?Thanks for the info
As far as I know this is the stock set up, but am not 100% sure. My fuse holder is white, about 2" long, and does use the glass fuse. It also has 4 ridges running the length of the holder. It sounds like the one on the firebird is very similar.
