a/c ?? on a 78
Old 04-30-2004, 12:34 AM
Today's problem is..
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Default a/c ?? on a 78
Hello everyone, I finally have my new engine, trans, rear end, front suspension and new interior in my car, so now its time for some frills! My car is a factory a/c car, but all the parts except for a few have been removed. The car has no compressor, condensor, brackets or hoses, what I do have appears to be a dryer/accumlator? and an evaporator, the dryer has what appears to be a pressure switch in it with wiring, the evap has a temp probe going to one of the lines and is wrapped in a/c insulation, I have no idea how long this system has been open like this, should i replace the evap? the orifice tube was left in it so i assume there wouldnt be any large debris in it. I know the dryer would need to be replaced. Also, where would the wiring for the compressor come from, I cant seem to find it and dont know if its been cut or not. Basically I just need to know the particular parts for this system, and I would prefer to convert it to 134a instead of r-12 since i need all new parts anyways. I dont see an expansion valve anywhere, is it built into something, or in the evap box? Any help, pictures, explainations on the a/c for this car would be greatly appreciated so I can get it nice and frosty.
---chris :steering:
Old 04-30-2004, 12:46 AM
comp
comp's Avatar
Default Re: a/c ?? on a 78 (Today's problem is..)
if mine i'd contact Vintage Air for one of their systems....
Old 04-30-2004, 07:59 AM
brooksman9
brooksman9's Avatar
St. Jude Contributor
Default Re: a/c ?? on a 78 (comp)
ttt curious myself :lurk:
Old 04-30-2004, 08:36 AM
90 KOTH
90 KOTH's Avatar
Default Re: a/c ?? on a 78 (brooksman9)
Hot Rod Air http://www.hotrodair.com/ also offers components to repair/replace/improve the C2 and C3 AC systems.
Old 04-30-2004, 01:45 PM
Missileman
Missileman's Avatar
Assuming that your interior controls are intact, you should replace the missing components (still relatively inexpensive or plentiful in junk yards). You should replace the evaporator because freon converts to acid when exposed to air and moisture, so there is no telling the condition of the inside.
To a/c ?? on a 78
Quick Reply: a/c ?? on a 78
