Master cylinder leak
The m/c on my 75 is leaking out the back of the cover. I opened the cover and found the back reservoir almost empty and the front one full. After refilling the reservoir I replaced the cap and have noticed some fluid slowly running down the back of the m/c. Do I just need a new gasket or is something else going on? Thanks for any help.
Re: Master cylinder leak (kaz1961)
Depends on whether it is comming from the cover or the body of the MC.
It is common for a MC to leak out from the rear piston. In that case it would need rebuilding.
[Modified by wombvette, 10:26 PM 4/29/2004]
The pistons seals are probably bad. You need to either replace the master or rebuild it. It is no cheaper to rebuild the master, but in my case I needed to keep the original numbers part so I rebuilt. It took an hour to remove, rebuild, bench bleed, reinstall. The warning signs are there, now heed the warning before you have bigger problems.
