funky noise when i don't use starter fluid.
when i use starter fluid, she starts up fine. When i don't she will crank over for about 2-5 seconds and then it sounds like the start is grinding, like the engine is trying to turn backwards and the starter forwards.
Location: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Re: funky noise when i don't use starter fluid. (munday)
Fill up the starter fluid, never let it run dry
:jester
:jester
Re: funky noise when i don't use starter fluid. (comp)
:skep: :skep: more imput... has it been sitting, etc
St. Jude Donor '09
Re: funky noise when i don't use starter fluid. (FeedVaal)
You must have put synthtic blinker fluid in....Thats a big :nono:
I always heard that starting fluid was bad for gas motor's.
Re: funky noise when i don't use starter fluid. (Desertdawg)
Just jetted down the carb, but she has done this since it started to about October when it started to cool down...I don't have a choke so there have been some hard starts. I am running a Demon 650 mechanical. Timing should be right on the money. It is possible the battery is weak, it is at least 2 years old and only 650 cca. Yes the car sat most of winter.
[Modified by munday, 4:40 PM 5/1/2004]
