Question for those with MAD TrueDual exhausts
Pic looks like there is an "H" crossover pipe between the duals right where they join to curve under the passenger side. Is this the case, or is it just a bracket ????
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Re: Question for those with MAD TrueDual exhausts (Vette-4-Life)
MAD's kit does not include an H Pipe.
I just put the chambered exhaust on my '77 last month. No "H" or cross over pipes :nonod:
:seeya Jeff
:iagree: :iagree:
The pipes run very close to each other as they bend toward the right side floorpan and under the pass seat, then back out as they near the rear end.
Installing an 'H' is on my "to do" list....
Re: Question for those with MAD TrueDual exhausts (Master Ho)
It's probably the bracket that you'll need that mounts with the trans mount. You need both pipes to be held up in position now, there's a bracket that will do both sides w/ a couple clamps. Look thru the exhaust posts, I got mine from a guy named Gordon,, Stage II system, I love it. They make the MidAmerica systems too supposedly.
Re: Question for those with MAD TrueDual exhausts (AGVI)
Do the MAD pipes work with the stock manifolds?
Re: Question for those with MAD TrueDual exhausts (Pauld)
My '80 L48 has headers so I had to do a little modification ;) It really wasn't that big a deal though. H-pipe install is the next thing to come though :thumbs:
Wouldn't one of those prefab "X" pipes from Summit fit well on that long, straight section on the right (passenger) side ???
[Modified by Fast81, 2:10 PM 4/30/2004]
