Painting advice for a 1979 Vette
3rd Gear
I was wondering if any one could give me advice on painting my vette. The old paint job is old and has cracks all over most the body, but not cracks that u can feel the paint off. I was wondering if i should strip the car down all the way and get rid of the cracks therefor eleminating the posssiblity that the new paintjob would crack. OR would it work just the same to sand down the paint, put a sealer coat of primer and then paint the car as normal. The only reason i am worried about the cracks is becuz i heard that the vibrations would cause the old cracks to crack the new paint job in time. Any Advice Appreciated thanks! :confused: :confused: :confused:
Re: Painting advice for a 1979 Vette (BurntGuitarist9)
I am no expert, but have painted a number of cars, I have always removed all paint that is checked or cracked down to base.... but I have never worked with fiberglass.... always old-lead sled muscle cars. I have a friend who sanded "some" only on his 68 shortbed pick-up's checked paint and not even a couple months later you could see his paint job check just like it was. Don't know if that helps, but although its alot more trouble to remove it all..... It will "guarantee" the old paint "will not" ruin your new paint.
Good Luck with it!!!
Loren :cheers:
Loren :cheers:
3rd Gear
Re: Painting advice for a 1979 Vette (TLChydraulics)
me and my brother just realized after examining the paint that the car was once black! something the previous owner did not mention :mad ,it also turns out that the car was painted white after that, and repainted white again :shocked: . Well n e ways the whole top back is sanded all the way, so i figure im going to try to sand down as much to get rid of all the cracks. Looks like i got alot of sanding ahead of me :D. thanks for the help!
