Sanderson headers help
I just installed my new sanderson headers(coated) and now have no way to install altenator. Any ideas? My heads are 461 so no bolt holes.....hmmm big problem.
Re: Sanderson headers help (brs6482)
I'm assuming your old setup used the first header bolt as a support for the alternator? Use the old bolt and make a spacer to make up the difference between the exhaust manifold size and header flange size...
-Steve
-Steve
Re: Sanderson headers help (Pacin'California)
The problem with that is the new headers only use 4 bolts instead of 6. It has a bolt on both ends and two on the middle chambers.
