High pressure sending switch
Old 04-27-2004, 09:53 PM
Wrecked82
Wrecked82's Avatar
Default High pressure sending switch
This lovely piece of work is connected to the high pressure line on the a/c and is just next to the oil dipstick on the passenger side. It is very susceptible to being knocked loose. My a/c has been working itermittently, either very good or not at all. Had freon checked - up to specs. Switch on compressor replaced last year and is nice and tight. Tonight, noticed the high pressure switch was cocked off center and loose. So, made a loop around the switch with cable ties, then another loop around the high pressure line and then connected the two loops with another loop - just tight enough to hold the switch connector in place.
Anyone have problems with the location and the switch coming loose?
Quick Reply: High pressure sending switch
