Who sells a full line of set screws??
I'm modifying a Q-Jet to my own liking and I tapped a couple of holes to 12-24 so I can plug 'em. But now I need 12-24 set screws. McMaster doesn't list 'em. Anybody have a source?
Am I gonna have to make my own?
:smash:
:smash:
Re: Who sells a full line of set screws?? (Silvr77)
Yes... I looked in cat #395.... no go. I'm going to a local industrial fastener supply house today.... if they don't have them, I'll get some machine screws and make my own set screws. 12-24 is an odd size.
Thanks
Tom
Thanks
Tom
Re: Who sells a full line of set screws?? (Tom454)
Checked in J&L Industrial Supply,MSC Industrial and Richards Machine and Cutting Tools catalogs and nothing listed under this size.looks like you will be making your own.
Re: Who sells a full line of set screws?? (COMMANDER370)
Try Copper State Nut & Bolt. I know they have severl stores in Phoenix. Not sure if there is one in your town.
http://www.copperstate.com/
[Modified by Zane, 8:54 PM 4/27/2004]
Tom,
Since you were kind enough to help me with my computer posting question yesterday maybe I can return the favor.
The Nutty company here in CT lists 12-24 set screws, check http://www.thenuttycompany.com hopefully they'll have the ones you need.
:thumbs:
Gary
:thumbs:
Gary
Re: Who sells a full line of set screws?? (Zane)
Thanks all...
I went to a local supply house (Wilders) yesterday and bought a couple of SS (18-8) machine screws and machined my own set screws out of them. I wanted stainless because I might have to remove them after my test. They're in a Q-JET M4MED to block the idle air bleed passages that go from below the throttle discs up to a slot just below the choke butterfly. The passages are "optional" depending on application and I think my application will work better without them.
Wilders had plain steel set screws, but I wanted to use SS to avoid corrosion and binding issues in case the test is a flop and I have to remove them.
Thanks again.
Tom
Thanks again.
Tom
