Clutch safety switch
Location: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I know that the previous owner diconnected my clutch safety switch so he could start the car without the clutch. I know that it is wired with a purple and yellow wire that are currently twisted together.
Can someone look at the switch at the top of the clutch arm and tell me which wire goes to wich terminal? Or better yet, take a picture? I don't feel the need to purchase a wire harness for this but want to hook it up correctly.
Thanks
Thanks
St. Jude Donor '05-'06
Re: Clutch safety switch (Ak. Mal)
It doesn't matter which one it goes to. Its a switch. All it is doing is going from an "open" condition (ie clutch not fully dpressed to a "closed" condition (ie clutch depressed).
It may be he disocnnected it because the position of ths switch needs to be adjusted. I had to adjust mine so that it was "closed" when the clutch was fully adjusted. Let me tell you that it is not a fun job unbolting that switch then getting it re-connected.
Good luck.
[Modified by stingry, 2:38 PM 4/26/2004]
Good luck.
Bubba done went crazy with the wire cutters and electrical tape in my car.
I can't count how many harnesses have been cut out and reconnected.
Thanks for the help on the switch. It actually just occured to me before checking this that the connection shouldn't matter. Sometimes you just have to think about things long enough before they make sense.
