Could this cause a missfire?
#7 was rubbing against the header... I need to think of a better way to get it routed.. there's not much room in there.
-Steve
Re: Could this cause a missfire? (Pacin'California)
Oh yeah, that would cause a misfire. The first time I took my girlfriend out in my 79, by the time we got to where we were going I had a misfire. When we arrived I raised the hood with the motor running and could see the wire arcing to the exhaust manifold. I just pulled the wire away and tied it back until I could get the car back home to fix it. Pretty embarassing to me but she never knew what was going on.
Re: Could this cause a missfire? (Eddie 70)
Running without a wire is ok?
I'm gonna head over to the parts store and pick up a box of cheapos until I can afford good looms.
Yes that burn spot on the boot will cause a misfire. :yesnod: I have proved this myself. I recommend some boot/wire protectors and I bought mine from summit for <$50 (they look like a sock but u can buy them in different collors to match your wires).
It's my personal opinion but I think any good 7.5 or 8mm silicone wires with wire wound spiral core will do a fine job. I just don't think the expensive name brand stuff is worth the difference in price. ;)
Steve,
Absolutely! Was doing a check of my plug wires tonight too. My number one plug was very gas fouled. I measured the exhaust temp about 1 inch below the flange on each of the primary header pipes while idling at a somewhat fast 3000rpm. My #1 was 580 degrees F, the others were about 890-950 degrees F. I put this plug wire on my ohm meter and found a measure of 1.948 compared to a measure of only .125 with the old MSD wires. Touching the connecters together makes a measurement of .000. My current wires are Jacobs ceramic wires guaranteed for life. I think I need a replacement.
Chuck
Chuck
Re: Could this cause a missfire? (Chuck Harmon)
For anyone wants a cheap trick, I usually found my wire short by using a mirror at night and look for the arcs. Hard to see during the day time but at night it's very clear where your problem is. Another tip is to use a timing light to check each each wire. The one that doesn't have a steady pulse could either be a cap, wire or plug problem.
