cutting coils; what end?
Greetings all. I've seen so much good stuff here regarding ride height, etc. Could you please tell me where you cut? Top or bottom?
Re: cutting coils; what end? (73 Vet)
The top end as the lowers seat into a pocket in the A arm is the end I cut. The present springs in my car are the F41 550 in/lb springs and set my fender lip height at 27" without modifications, you may want to investigate Vette Brakes of other vendors for springs, there not that much at around $80 and may work better for you.
Senior Member since 1492
I cut the bottom(larger coil spacing) with a cut off wheel. :chevy
