Street Avenger vs. Road Demon...
Old 04-23-2004, 04:51 PM
e3pres
e3pres's Avatar
St. Jude Donor '08-'09
Default Street Avenger vs. Road Demon...
I'm about to buy a carburetor. I've heard good things about both the Street Avenger as well as the Road Demon. Which would you suggest and why. BTW this is going on a 350 with an XE268H, Edelbrock Performer Intake, and Headers. I'm looking at the 650/670 cfm models.
TIA,
Old 04-23-2004, 04:56 PM
79VetteMike
79VetteMike's Avatar
Default Re: Street Avenger vs. Road Demon... (e3pres)
Good poll. I have the exact same question.
Old 04-23-2004, 05:09 PM
verskel
verskel's Avatar
I'm voting Road Demon just because recently I haven't had much luck with the Holleys being great performers. They'll get the job done but it seems like the Demons always do a little better in the performance category (probably because of the nice smooth venturis).
Have you thought about spending a few more $$$ for a Street Demon ?
[Modified by verskel, 4:09 PM 4/23/2004]
Old 04-23-2004, 05:11 PM
TTop Tony
TTop Tony's Avatar
I loved my street avanger. I still have it. I couldn't get the road demon to idle so I sold it. Probably something i was doing. if you so get a demon carb call there support line and they can tell you which one to use for your carb.
Old 04-24-2004, 06:15 AM
1979toy
1979toy's Avatar
Default Re: Street Avenger vs. Road Demon... (TTop Tony)
Tell us more about your setup. My choice would be with the Speed Demon if you are inclined toward performance and don't mind a bit of tuning. My last engine had a Holley Street Avenger and I was quite pleased with it....until I tried a Speed Demon!
Old 04-24-2004, 11:41 AM
Corey_68
Corey_68's Avatar
Default Re: Street Avenger vs. Road Demon... (1979toy)
Here's my take:
Speed Demon - Weekend Toy
Street Avenger - Daily Driver
Old 04-24-2004, 05:42 PM
e3pres
e3pres's Avatar
I ended up going with the Street Avenger. I picked it up today. Hopefully I'll put it on this week. I'll be sure to give a full report.
Old 04-24-2004, 07:14 PM
GTR1999
GTR1999's Avatar
Received 2,613 Likes on 1,336 Posts
Keep us posted. I have a new 670 SA ready to bolt on to a L-82 with Xe268 cam, WP Sportsman heads,RPM intake,headers,etc.
You should do a search to find Lars post on carbs,he said to check the throttle plates on new carbs because they aren't set right from the factory.
Gary
Old 04-24-2004, 10:00 PM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Street Avenger vs. Road Demon... (gtr1999)
I have the 670 SA on mine. So far so good. The car fired right up and ran good. I had to adjust the idle speed down though. I need to check into that part about throttle plates.
Old 04-25-2004, 01:22 PM
e3pres
e3pres's Avatar
Default Re: Street Avenger vs. Road Demon... (Eddie 70)
Did Bob make you buy one too? :lol:
Old 04-25-2004, 05:46 PM
Eddie 70
Eddie 70's Avatar
I wound up buying it own my own just because of what I had read on here. I didn't even know Bob at that time.
Did you get yours installed? And how is it working?
Old 04-25-2004, 07:13 PM
e3pres
e3pres's Avatar
I don't have it installed yet. I'm trying to finish up school here in Cookeville and my car is in Chattanooga. :cry I'm hoping to get down there this week to put it on, but I may not get to.
Old 04-25-2004, 08:29 PM
lostpatrolman
lostpatrolman's Avatar
If your avenger came with the clear sight plugs, I would recommend taking them off. After about a year, they get hard and break. The head will either twist off if you are trying to take it off, or it will just fall off on its own. This leaves the threaded part in the carb still. Since the head had the gasket part on it, some leaking of gas could also occur.
Old 04-28-2004, 03:18 PM
69schemers
69schemers's Avatar
I have heard that if you want all out performance, run the Demon. I have also heard from several people that the Demon runs rich at low RPM's. Not somthing you would want if you are cruising down the highway in overdrive.
If your not racing, get the Street Avenger
To Street Avenger vs. Road Demon...
Quick Reply: Street Avenger vs. Road Demon...
