What Is The Best Way To Lower A C3???
What is the best way to lower a C3? Are there any websites one can go to that gives directions on how to do this procedure properly? Does anyone offer a lowering kit for the C3's? I would greatly appreciate any help with this quest for knowledge.
Re: What Is The Best Way To Lower A C3??? (dtengle)
You can do a search with " lower " key word or go to http://www.corvettfaq.com and look for suspension.
I am having problem with mine right now. Good luck
Re: What Is The Best Way To Lower A C3??? (myisa69)
longer bolts in the back and cut the springs in the front is the way to go
as said look at corvettefaq for more info
Re: What Is The Best Way To Lower A C3??? (stingraymaniac)
For me the best option was to go w/ VB Performance Plus Sus. Kit. It allows you to easily adjust both ride height and spring rate for front and rear. In my situation the vette needed new balljoints, ends, and etc. All of the rubber parts are replaced w/ poly. I love the kit.
