Control and A arm question
Do those control and a arms look like the go to a c3? They look like c4 arms to me. Anyone else care to shed some light on the matter?
http://www.ecklers.com/product.asp?d...EULPBA9AV64VB0
Re: Control and A arm question (wgc_3)
That looks a lot like Vette Brakes Performance Plus system changing to a tranverse mounted mono spring in the front. Several members here have done this upgrade, hopefully someone that's done it will chime in.
I believe this a Vette Brakes kit that uses custom built A-arms. This has been on my wish list for years. Go ahead spend the money - keep the economy going!
Re: Control and A arm question (GasketDude)
yes, it is the vette brakes systems, the lwoer arms are required when using the transverse system that does not use those mushroom type hangers (for stock arms), the upper arms are tubular also. They're stronger than stockers and available with a larger caster option.
