Junk the smog pump.
Junk the smog pump.
I just got an 81. I am in the process of replacing the water pump. It appears that the brackets for the smog pump hook on to the water pump. since it looks like I have to take off the smog pump, I would like to leave it off. I live in a state that does not have inspections so that is no problem. Since this car has a computer controlled carb, is there any problems leaving the pump off?
Re: Junk the smog pump. (vetteman1100)
You will need to cap off the air tubes, just remove the check valves and replace with pipe caps. Also I never ran without my smog pump, but if your check engine light comes on you may need to jumper the 2 connectors with resistors. Not sure of the size, but you can probably measure the resistance across the solenoids on the smog pump.
