C-3 "tube frame"
C-3 "tube frame"
How cool is this?? NO it isn`t mine!!
http://cgi.ebay.com/ebaymotors/ws/eB...900795284&rd=1
Re: C-3 "tube frame" (redvetracr)
Check with 542C2, he has a backhavled 69, full tube frame he wants to sell. Made for going in a staight line
Re: C-3 "tube frame" (Corey_68)
wow if i wasnt building an addition to the house id jump right on it,hmmmm lets see, if i dont put a roof on it or sheetrock i could get it :D
Re: C-3 "tube frame" (ZD75blue)
That is extremely awesome I would love to slide that under my vette. :smiliedrool: :smiliedrool: :smiliedrool: :smiliedrool: :smiliedrool:
Re: C-3 "tube frame" (78 Vette)
Very interesting! I wonder, where does the gas tank go? Above those tubes at the rear? If so, you need to remove the body to change the tank (if ever a problem...).
Sweet ... but then you need a C4 donor car for all the suspension.
I guess that's the only advantage - C4 suspension, since the tube frame doesn't look much lighter than the stock one.
I'll stick with my restored box frame for now.
Re: C-3 "tube frame" (Twin_Turbo)
it probably won't be lighter but it sure will be a hell of a lot stiffer than the stocker.
:seeya That is a cool frame he also get's them powder coated. He seems to use that style frame for all his Classic (C1-C2) build ups that he does from scratch. :yesnod: The new building and shop is really awesome. :thumbs: So if you are ever get a chance to come to the Charleston, SC area you should drop by their shop. :cheers:
