What is the diam. of the hard brake lines in front?
Old 04-22-2004, 10:42 AM
71stingraybigblock
71stingraybigblock's Avatar
Default What is the diam. of the hard brake lines in front?
I need to replace the hard line that connects to the flexible brake line on the drivers side. I figure I would just buy a short piece from auto parts store but I need to know the diameter.
Old 04-22-2004, 10:54 AM
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: What is the diam. of the hard brake lines in front? (71stingraybigblock)
My '78 measures at about .190" so about 3/16ths OD.
Old 04-22-2004, 12:09 PM
71stingraybigblock
Default Re: What is the diam. of the hard brake lines in front? (burners)
thanks burners
Old 04-22-2004, 12:10 PM
71stingraybigblock
Burners,
What do you think of the Spherical rod end clutch linkage?
Old 04-22-2004, 12:15 PM
burners
burners's Avatar
Cruise-In V Veteran
You're welcome. The clutch linkage definitely smooths out the clutch operation and it gets rid of the annoying squeeks that the stock system usually has. Naturally, I'm a bit biased about this but I think it's a good upgade.
To What is the diam. of the hard brake lines in front?
Quick Reply: What is the diam. of the hard brake lines in front?
