Gastank build sheet
Gastank build sheet
I would like to get my build sheet from my gas tank. The problem is that I dont know if its the original gas tank. So before I drop the tank, which i understand is the only way to recover the sheet I would like check if theres a build sheet there.
Does anyone have a way that they have tried and it worked to determine if a build sheet is on the tank prior to dropping it? :confused:
Received 6,943 Likes
2015 C2 of Year Finalist
Re: Gastank build sheet (deisenreich)
a long stick with a mirror and a flash light. :thumbs:
I havr found a few of them, you can see them through the gas top by the gas tank lid, so I wouldnt drop the tank unless you can see one , just take off your gas cap door and the rubber boot, shine a small flashlight on top of the tank , sometimes they are covered in grime so look carefully for anything sticking up. I had my daughter with very small hands reach in a peel one off for me.
