Choke Adjustment(s) Speed Demon 650 Need help..
I am having an issue with my choke as pointed out in previous post....
Need some help with Electric Choke adjustments:
Problem: Car has a miss till its heats up to approx 180 degrees.
I adjusted the black 'can' onside of crarb..spun counter clockwise...is very tight even with three srews loose...
Ohter problem: I never seem to get a 'fast idle'. I have to sit there and pump it till it starts to warm up.
What other adjustment isd there?
Can you spin the black choke housing around a few times to loosen it up???
Thanks for ther help... :cheers:
