How to lower a 77 Vette.
Re: How to lower a 77 Vette. (slvrbullit)
...Let the air out of the tires :lol: :jester
Other than that...you can get the longer rear spring bolts that will bring the back down, and if you have the means you can "cut" a coil or so from that front springs.
:cheers:
:cheers:
Seriously though, Mid America has kits for something like $499 that has the shorter (and stiffer) front springs, and as already mentioned, the longer bolts will take care of the rear. Although I haven't used the longer bolts on the rear, I assume it would bottom out easier untless you went to a heavier duty spring as well. But maybe I really don't know what the heck I'm talking about either... :crazy:
Re: How to lower a 77 Vette. (Wendell Allen)
and when you lower it in the rear you gonna ned adjustable strutrods
to take care of the wheel alignment :smash:
WHY would you want to? Does it sit abnormally high now? If so then something is wrong.
Install tires with a smaller diameter (profile difference) on your current rims..... if you can find some.
Thanks for the replies guys.
I wish I could afford a big block :)
It's not so much that I want to lower the car. I just want to mainly kill the gap between the fender and the tire. If I go with smaller tires the car would sink but I wiould still have the problem of a large gap between the tire and fender.
How do the longer bolts lower the rear? I would think a lowering block would be needed out back???
In the rear suspension the bolt at either end of the rear spring is what ties the spring to the trailing arm/spindle assembly. By installing longer bolts you can lower the ride height without changing the spring.
Anyone have specs on these bolts for the rear? What size are they, where can I get them??
Thanks a lot for all the replies!
St. Jude Donor '05-'06
Here are some ideas. Mix and match if you want.
Cut front springs (1 coil appox 1") $20 for oxy gas 3 hours
Fit shorter springs $60 for springs + $20 shipping + 3hours to install
Longer bolts for rear spring $40 for bolts and 1 hour (1-2" depending on bolt_
Fill in fender gap - fit larger tires. 225/70/15 are 1/2" taller then 215/70/15. Go to tirerack.com and look at different tire sizes. Remember too tall/wide and it will effect clearances. Ask other forum members what fits. Tires $250+ and 2 hours to fit.
Good luck.
Good luck.
Shorter FE-7 (550) springs & VB rear spring w/ longer bolts. The rear will come down if you drive very hard & then stock bolts can be used.
:cool:
:cool:
