Steering Wheel Swap
Steering Wheel Swap
I've got my orginal wheel out of my '82 but I can not figure how the new one is supposed to work. It's a MoMo wheel and hub. They tell me I have the correct hub but I can't figure what to connect the wire from the hub to for the horn to work and I can't see what will freeze the steering shaft from just free floating up and down. I was told up front that I would loose my telescopic but now the shaft just free floats up and down. Anyone every have this problem?
[Modified by Casper, 9:37 AM 4/20/2004]
Re: Steering Wheel Swap (Casper)
I think you have to but the center bolt back in without the ring. Find the tele-position you like and tighten it down. This will lock the slider.
Re: Steering Wheel Swap (markdtn)
If for some reason you can't lock the telescoping feature by using the original "star" screw, you can use a 5/16-18 UNC set screw (#20 Allen Screw) in its place.
Re: Steering Wheel Swap (Jim Shea)
That sounds like my problem. I have not tried putting that screw back in. I can deal with the horn issue later. Thanks guys!
