Anyone have any pics of there 1980 Exhaust???
Would love to see some pics of some true duals on an 1980? Or some info for my friend again! He is going tommorrow to buy some stuff......What to buy?
Re: Anyone have any pics of there 1980 Exhaust??? (88BlackZ-51)
I have no photos of my undercarriage, but I would recommend getting the true dual kit from MidAmerica :thumbs: I installed a set on my '80 with headers (you have to do some modification) and flowmasters :yesnod: It's not that hard, and the difference is awesome :thumbs: :flag :thumbs:
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
If you don't have to run converters, the install is easy. Just remove the front Y pipe and run a single pipe from each manifold and route them the same way as the stock exhaust was. Tack weld them together and run them down the passenger side (good place to put in a "x" pipe connection too) and then split them again at the rear using the back half of the factory Y pipe in the rear.
Re: Anyone have any pics of there 1980 Exhaust??? (vetteonr)
Hey Vetteonr...how did you get your radio antenna on an angle like that...I need to that to mine!
