BBC fuel pump clearance issue...which plug to use???
Old 04-19-2004, 10:24 PM
74FLCONV
74FLCONV's Avatar
Default BBC fuel pump clearance issue...which plug to use???
Does anyone have a pic, or can you describe, the correct plug which belongs in the threaded hole in the block immediately under the fuel pump (I believe it is an access hole to remove/install the fuel pump push rod). The current plug is hitting the fuel pump, not allowing it to be bolted in all the way.
Thanks in advance,
D. Ocean
Miami, FLA
Old 04-20-2004, 12:44 AM
SWEET74
SWEET74's Avatar
Default Re: BBC fuel pump clearance issue...which plug to use??? (74FLCONV)
I believe it is a 5/16" or 3/8" pipe plug with sealer on it. If you use a standard bolt it will go too far in and hit the shaft. The hole is there so you can hold the pushrod up while installing the pump.
Old 04-20-2004, 08:19 AM
70BBvert
70BBvert's Avatar
It's an allen head pipe plug. Got one from the machine shop that does all my work. I'll see if I have a picture somewhere
Jim
Old 04-20-2004, 08:27 AM
74FLCONV
74FLCONV's Avatar
Default Re: BBC fuel pump clearance issue...which plug to use??? (70BBvert)
That explains alot. The previous owner was using a plug with a head on it (vs. allen head) and that is hitting the pump. I'll find an appropriate-sized allen head plug.
Thanks,
D. Ocean
Miami, FLA
Old 04-20-2004, 09:17 AM
SWEET74
SWEET74's Avatar
Actually the head does not matter, just make sure that it is pipe thread and not USS or SAE. It will come with either an allen or 4 point head. Do not forget the sealer. Rectorseal #5 works well.
Old 04-20-2004, 09:43 AM
70BBvert
70BBvert's Avatar
Default Re: BBC fuel pump clearance issue...which plug to use??? (SWEET74)
Actually, there's not a lot of room there. The recessed allen head is needed to clear the pump. A regular pipe plug with a raised square will not allow the pum to sit flush against the block.
Old 04-20-2004, 09:47 AM
Garys '68
Garys '68's Avatar
Mr Ocean, I see we frequent the same forums, OSO and Vette.
Thought I was having a little deja vu reading this. Find the right plug?
Gary
Old 04-20-2004, 07:45 PM
74FLCONV
74FLCONV's Avatar
Default Re: BBC fuel pump clearance issue...which plug to use??? (Garys '68)
Yep. Found an allen-head pipe thread.
Thanks for the replies, all.
D. Ocean
Miami, FLA
Old 04-20-2004, 08:29 PM
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
D. Ocean
Miami, FLA
What size? :confused:
Old 04-20-2004, 09:36 PM
74FLCONV
74FLCONV's Avatar
Default Re: BBC fuel pump clearance issue...which plug to use??? (Jughead)
Not sure of the "official" size, but it measures 5/8" in dia.
D. Ocean
Miami, FLA
Old 04-21-2004, 06:13 AM
Jughead
Jughead's Avatar
St. Jude Donor '09
:thumbs:
To BBC fuel pump clearance issue...which plug to use???
Quick Reply: BBC fuel pump clearance issue...which plug to use???
