15 gallon Fuel Cell for '77 vette
4th Gear
Does anyone know of a company who makes a 15-20 gallon fuel cell with sending unit as a direct fit for a '77 vette? Thanks.
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: 15 gallon Fuel Cell for '77 vette (glock22_40)
I don't know of anyone that sells a direct fit fuel cell for the 77 C-3, there are replacement fuel tanks available from Quanta Products, http://www.quantaproducts.com/store/...em=13&mitem=13
Fuel Safe sells a fuel cell, but it will cost you. Its a 19 gallon direct fit unit for a little under $1000.
I can make you a 15 to 20 gal WATER tank out of 5053 aluminum with a bottom sump at any height you require (if you looking to lower the cg of the tank). Cost might work out to the $500 to $600 range but it will be blatterless unlike the Fuel Safe setup. Other trick features would be to add fuel cell antislosh foam and a bottom rear sump. If interested drop me an email.
