differences in rear spring
I would like to know what are the differences between the rear springs on the auto and manual transmission 2001-2004 vettes.
The reason I ask is that someone gave me a Z51 rear spring off an automatic car (part No. 22146646) and I want to know if it fits on my M6 2001 vette.
Re: differences in rear spring (Dan_the_C5_Man)
Not sure what the differences are, but there are differences.
The part number he listed is in fact listed as for an Automatic, the part number for a Manual trans is 22179020.
It seems from LS1howto.com that there is no difference... just wanted to know for sure before I pulled the springs off and checked the old fashioned way.
Re: differences in rear spring (sprinter)
The FE-1 springs are rated @439.66lb. front, @576.70lb. rear manual tranny, @588.12lb. rear auto tranny. The FE-3 springs are @525.31lb. front, @633.80lb. manual tranny, and @645.22lb. auto tranny. I installed used Z51 manual transmission springs on my AT vert.
Re: differences in rear spring (powderski13)
"The FE-1 springs are rated @439.66lb. front, @576.70lb. rear manual tranny, @588.12lb. rear auto tranny. The FE-3 springs are @525.31lb. front, @633.80lb. manual tranny, and @645.22lb. auto tranny. I installed used Z51 manual transmission springs on my AT vert."
Does this mean that there are not any physical size differences and I will be able to install the A4 rear spring with no fitment issues?
You say the A4 rear spring can hold a higher load, does this mean that the A4 spring is stiffer than the M6 spring? ...and therefore would be the preferred rear Z51 spring.
Saying that, I doubt the small difference will make much of a difference, other than probably riding a bit harsher than a factory Z51.
Re: differences in rear spring (Tony_C5_04)
Thanks guys for your help. I mainly post over on LS1Tech but you guys here are definately the Vette experts!
I will buy the Z06 sway bar kit to complete the upgrade. I was very lucky to get my grubby little hands on these "factory sample" sway bars (a Z06 front and the Z51 A4 rear) ...for free mind you! :yesnod:
I still have to get the engine back together first... installing ported/valves/springs LS6 heads, CC224 cam and Kooks headers.
