Cleaning Driveway..........
Old 04-19-2004, 09:45 AM
lvrpool32
lvrpool32's Avatar
Default Cleaning Driveway..........
whats your suggestion for cleaning oil/ grease stains off of the driveway?
Had my driveway sealed last year and had a slight mishap with changing oil yesterday...need to clean the driveway now...any suggestions?
cheers
Nick
Old 04-19-2004, 10:10 AM
markdtn
markdtn's Avatar
Default Re: Cleaning Driveway.......... (lvrpool32)
Concrete driveway? 2500+ psi pressure washer will do it pretty well.
Old 04-19-2004, 10:12 AM
70BBvert
70BBvert's Avatar
I've been using POR-15"s Marine Clean. Works pretty good, just don't get it on any aluminum wheels.
Jim
vetteboy1976kr
vetteboy1976kr's Avatar
I use the driveway cleaner made for pressure washers. I think that it is made by DEP and it's purple. I get it at Home Depot for like $8 a gallon. I mix it 1:1 with water and on the really tough spots I go full strength. I let it sit for 1/2 hour and then scrub it off with a broom. Then rinse with lots of water.
Old 04-19-2004, 09:34 PM
phxraptor
phxraptor's Avatar
Tide made into a thick paste spread on oil/grease let soak scrub with stiff brush and hose off till all soap is gone ;) :cheers: :seeya
Old 04-19-2004, 09:43 PM
garandfan
garandfan's Avatar
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Default Re: Cleaning Driveway.......... (phxraptor)
coca-cola on oil/grease stains on concrete
Old 04-19-2004, 11:13 PM
Big Fish
Support Corvetteforum!
Big Fish's Avatar
A CI-6 Car Show Winner
Sawdust or commercial absorbent (even cat litter works) Let it soak it up and then dishwashing machine detergent and a stiff brush. I think many of the degreasers will also lift your sealer.
Old 04-19-2004, 11:44 PM
74FLCONV
74FLCONV's Avatar
Default Re: Cleaning Driveway.......... (Big Fish)
:iagree:
Although it may be too late, keep a bag of kitty litter (the cheap clay stuff) around during your next oil change. If you dump that on soon after the spill, it will absorb everything right off the concrete.
D. Ocean
Miami, FLA
Old 04-20-2004, 01:36 AM
jetlag
jetlag's Avatar
Default Re: Cleaning Driveway.......... (74FLCONV)
I agree with 74FLCONV, kitty litter works :)
Old 04-20-2004, 02:07 AM
Z-man
Z-man's Avatar
Default Re: Cleaning Driveway.......... (jetlag)
I use engine degreaser. Spray it on, hose it off...
Old 04-20-2004, 09:13 AM
tshort
tshort's Avatar
CI 7-8 Veteran
I used to pressure wash my driveway and sidewalk until my dad suggested using bleach and a stiff brush. The bleach seems to clean just as good but lasts much longer.
Old 04-20-2004, 12:00 PM
lvrpool32
lvrpool32's Avatar
Thanx guys.....looks like I have to take a run to the grocery store.....bleach, coke, kitty litter and tide.
I'll let you know what works...........
Nick
Old 04-20-2004, 08:46 PM
Motor City Vette
Motor City Vette's Avatar
Kitty litter soaks it right up.
Old 04-20-2004, 09:09 PM
garandfan
garandfan's Avatar
Default Re: Cleaning Driveway.......... (garandfan)
What no second on the coca cola!! Try it the acid will eat any thing!!
Avid coke drinker!! :)
Old 04-21-2004, 08:54 AM
KenSny
KenSny's Avatar
:iagree: A couple of years ago my wife spilled some coke on the car hood and promply forgot about it and left it sitting in the sun to dry. A couple of weeks later you could see the damage it was beginning to have on the paint.
:banghead:
Old 04-21-2004, 09:22 AM
stingry
stingry's Avatar
St. Jude Donor '05-'06
Purple Power from Wal-Mart. Its like $4 for a gallon and works well. For extra oomph wash the residual Purple Power/Grease mixture off with a pressure washer. ($100 for a 1400PSI K'archer from AMAZON.COM).
Old 04-21-2004, 01:35 PM
ettev
ettev's Avatar
Default Re: Cleaning Driveway.......... (Z-man)
:iagree: I also buy a few cans of the cheap brake/parts cleaner. Spray it on....hose it off. If it's a tough one I'll get out the stiff bristle brush with some industrial detergent and scrub the spot after I spray on the brake/parts cleaner but before hose down. I have brick pavers and have good results.
To Cleaning Driveway..........
Quick Reply: Cleaning Driveway..........
