Project Update. It turns over.....
Cruise-In VII Veteran
St. Jude Donor '07
Well after taking a week off, I jumped back into the LS1 conversion. I hooked everything up to the rebuilt column and bypassed the neutral safety switch, then turned the key. Well it cranks. That was a big relief.
Problems to still work out.
The neutral safety switch seem to be running backwards. The switch opens when the pedal is pushed in. Some how I must of installed it upside down.
Another problem popped up after the clutch master cylinder was install. The pedal throw is only about two inches. I will remove it and redrill three or four holes for adjustment.
Progess, but not perfection. So I will keep at it.
[Modified by Budman78, 8:30 PM 4/18/2004]
